There is CBB serial board may you need
https://docs.google.com/document/d/1sgurQ-7gLyn7g-Kg983NRM0aDkYEqHqy9dmrieX_RUM/edit#
I do the test with a simple module
https://github.com/digitalbond/canbus-beaglebone
That may help you with set up CAN bus with Beaglebone Black
The import things that you should disable HDMI
add
capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN
to
/boot/uEnv.txt
GrayPillow
