3 Axis test
A project log for AnanasStepper 2.0 - 3.0
Open Source CAN Bus Based Servo Stepper for Multi Axis Gang Control
GrayPillowGrayPillow 07/13/2017 at 15:074 Comments
This a start test of 3 axis aplication
David H Haffner Sr wrote 07/13/2017 at 20:24 point
Quite amazing, lookin' good so far :) I'm wondering just how small can UR driver board get, because it sure would be the ticket for my projects triple turret mount that uses the 28YBJ-48 stepper MTR, as of right now I have to use an Atmega 2560 to control the turret mount control assembly and it would be ideal to have it all fit nicely under the enclosure?
Enclosure dimensions: 248 X 190 X 109 mm
GrayPillow wrote 07/14/2017 at 01:10 point
Hi David ,As I know 28YBJ-48 stepper is too small.  I am sorry, Ananasboard is design for 42mm stepper.
David H Haffner Sr wrote 07/14/2017 at 09:56 point
Ah, that's cool, this still gives me some great ideas and a new direction that I might not otherwise thought of :)
GrayPillow wrote 07/14/2017 at 12:24 point
Congratulations , look forward to your work!
