AnanasStepper 2.0
Open Source CAN Bus Based Servo Stepper for Multi Axis Gang Control
This is a part of a smart Robot control system(AnanasRobot), based on Stepper Motor and CAN bus.This project aims to build a motion control system including hardware and software to make Multi-Axis Gang Control easy and precise, applied to 3D printer, a 6+ axis robot arm or some more complex motion control system.
Main Features:
1.CAN bus based(up to 1 Mbit).
2.STM32 32bit ARM MCU(Cortex-M3 72MHz).
3.Closed loop control with 14bit magnetic encoders(TLE5012).
4.Driver integrated(A4988 DRV8825 or more power MOS Driver)
5.Extendable(For more than 12+ motors), and Easy for Installation(With two twisted wires and power to get the whole system available).
6.USB-CAN Adapter and SPI-CAN Adapter For systems without CAN bus.
7.API for multiple control systems(Arduino Windows Linux Mac LinuxCNC Marlin Smoothie Repetier .etc).
AnanasStepper 1.0:https://hackaday.io/project/20980-ananasstepper
WebPage: https://ananasrobot.github.io/AnanasStepper/
AnanasStepper 2.0
This an upgrade of AnanasStepper(https://github.com/Dark-Guan/Ananas), which is a stand alone closed loop stepper driver.With STM32 MCU, this version has more performance to driver stepper well and CAN Bus support.
AnanasStepper
(CAN bus Stepper)
dir/step (I2C Serial)
with PID Stepper
Nomal dir/step Stepper
Closed loop
position
control
YesYes No
Step/Dir NoYesYes
Torque
adjust
YesYesNo
Temprature
(motor and
driver)
YesYesNo
CAN bus
Support
Yes Need to extendNo
Application Of AnanasStepper 2.0
There is plan to build a system with a Robot Arm and a 3D printer working together!
Coming Soon!
2 AnanasSteppers Do 2D plotter (test TWO Axis Gang Control)
I use 2 AnanasStepper to build a 2D plotter, Test 2D Axis Gang Control.
About https://hackaday.io/project/20980-ananasstepper-20/log/60311-2-ananassteppers-do-2d-plotter
AnanasStepper 2.0 play MIDI MUSIC
I tested AnanasStepper to Play MIDI music,And used My guitar as a loud-speaker!
It is not very nice but it works!!
Q&A:
https://hackaday.io/project/20980-ananasstepper-20/log/60341-qa-about-ananasstepper-20-1
CAN : https://en.wikipedia.org/wiki/CAN_bus
Portable Network Graphics (PNG) - 36.03 kB - 06/10/2017 at 16:25
Preview Download
Portable Network Graphics (PNG) - 37.51 kB - 06/10/2017 at 16:25
Preview Download
plain - 2.79 kB - 06/10/2017 at 16:25
Download
plain - 2.57 kB - 06/10/2017 at 16:25
Download
x-zip-compressed - 86.69 kB - 06/10/2017 at 16:22
Download
View all 11 files
  • 1 × STM32F103CBT6 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × TLE5012B Semiconductors and Integrated Circuits / Misc. Semiconductors and Integrated Circuits
  • 1 × TJA1050
  • 1 × A4988 Power Management ICs / Motion, Motor and Servo Control
  • 1 × DRV8825 Evaluation, Demonstration Kits, Boards and Modules / Evaluation Kits, Boards and Modules
View all 25 project logs
  • 1
    Prepare(Prepare AnanasStepper include Power wire and CAN bus wire)
    BOM:
    1. Ananas(AnanasStepper 20)
    2. Step Motor (2 phases-step-motor)
    3. Magnet
    4. Mount Space (a 3D printer part)
    5. Screw(4 Screw)
    6. Nuts(4 Nuts)
    7. Motor Wire
    8. Power Wire
    9. USB-CAN(or SPI-CAN)
  • 2
    Assemble Magnet And srew
    1. a.Assemble the 3D printed spacer.
    2. b.Assemble the Ananas.
    3. c, Final assemble the Nuts.
  • 3
    Connect AnanasSteppers(Power and CAN bus)
    First, Prepare All wires.
    Connect them follow the arrows.
View all 4 instructions
ottoragam wrote 06/13/2017 at 20:51 point
Hi, thanks for the follow! I see that you want to make a higher current drive. May I suggest a discrete array of half bridges? There are dual MOSFETs in 5x6 packages that should be able to handle the current you want or even more, and they don't take a lot of board space. Could give good results, IMO :)
GrayPillow wrote 06/14/2017 at 02:33 point
Thanks for your suggest. Yes I plan to use a dual MOSFETs in SOP8 package and IR210x mos driver to build a drive for This project. And I should do some more Test.
Your project is awesome, I like them.
ottoragam wrote 06/14/2017 at 03:50 point
Cool! What is the maximum motor voltage that you're planning on supporting?
GrayPillow wrote 06/14/2017 at 04:20 point
I'd like set the maximum to 24V , which affects component selection. About this part, What's your suggestion?
ottoragam wrote 06/14/2017 at 04:34 point
Well, higher voltage will get you higher motor speeds. The FETs start to become kinda expensive and less available beyond 80V, and I feel the IR210x gate drivers will be sort of wasted at 24V (they can go up to 600V), so maybe you can go with a commonplace 48V system. But if you choose 24V, The DRV8701 (the one I'm using) its a good candidate, as it includes an internal 12V supply for the FET gates (the IR210x doesn't).
GrayPillow wrote 06/14/2017 at 05:50 point
Thanks very much , I will consider your suggestions.
TegwynTwmffat wrote 05/31/2017 at 16:08 point
How many amps can this board handle? Thanks!
GrayPillow wrote 06/01/2017 at 01:40 point
Thanks for your comment.
Amps is limited by the driver used, A4988 is 2.0 A(max) and 1.4A rms, DRV8825 is 2.5A max and 1.75A rms. And I have a plan to embed MOS driver onboard, which may make the max Amps to about 5A + coming soon
Oskar Weigl wrote 05/29/2017 at 01:38 point
Do you plan to support industry standard protocols like CANOpen CiA 402? https://www.can-cia.org/can-knowledge/canopen/cia402/
GrayPillow wrote 05/29/2017 at 01:49 point
Actually, I read the CANOpen protocol and consulted some engineers familiar with it. And I figure out it is so complex. So I write another protocol for my system . My goal is simple and efficient , with some reasonable expansibility.
Oskar Weigl wrote 05/29/2017 at 01:56 point
Okay fair enough. What about using stuff already written, like https://github.com/CANopenNode/CANopenNode and http://wiki.ros.org/canopen_402 ?
GrayPillow wrote 05/29/2017 at 01:53 point
But, if it is necessary , I want to support it though it means I should do a lot of change with my system.
GrayPillow wrote 05/29/2017 at 02:08 point
I am not familiar with http://wiki.ros.org/canopen_402 now. But I have the plan to support ROS. I will try it later.
Thorsten Eggert wrote 05/11/2017 at 19:45 point
Nice thing. I just searched for some info to build something like this by my self. I only do not understand the CAN bus decision. I like the CAN bus and its features, but how do you plan to connect it to a grbl or similar? Or is the ananas 2.0 no meant to be used for hobby CNCs / 3d printers?
GrayPillow wrote 05/12/2017 at 01:43 point
Thanks very much!There are several way to connect AnanasSteppers 2.0 to normal CNC system , Serial to CAN or SPI to CAN (They are very cheap ,no more then 10 dollars).Ananas 1.0 is a version that support DIR/STEP and I2C interface .
I am foucing on AnanasStepper 2.0 Now ,After Releasing Python API , A C/C++ API is on the way.
Thorsten Eggert wrote 05/13/2017 at 14:07 point
So if I understand you correctly, grbl / marlin will need a CAM interface to be used, right?
If thats the case I would like to help, do you already have some informations about the protocol at the CAM bus?
GrayPillow wrote 05/13/2017 at 14:27 point
You are right! I am test the protocol Today. The demo test will be released Soon!!
Thanks for your hope to help! I will remind you soon!
Ryan Won wrote 04/11/2017 at 00:53 point
Would you like to share the fritizing files of the old ananans stepper?
GrayPillow wrote 04/11/2017 at 02:07 point
Yes,you can get them form the link of github I shared
GrayPillow wrote 04/11/2017 at 14:33 point
Oh, I am so sorry ,Today I check my github ,there is no fritizing file. I think I lost them.
Don't warry ,the more detail is here https://github.com/Dark-Guan/AnanasBoard , which is used Eagle . Hope this help you!
aape01 wrote 04/07/2017 at 05:42 point
很好
GrayPillow wrote 04/07/2017 at 23:53 point
Thanks!
Ryan Won wrote 04/07/2017 at 05:25 point
looks great
Thanks!
navichan wrote 04/07/2017 at 05:16 point
Very nice!
Thanks!
