Run of AnanasStepper 1.0
A project log for AnanasStepper 2.0 - 3.0
Open Source CAN Bus Based Servo Stepper for Multi Axis Gang Control
graypillowGrayPillow 04/12/2017 at 14:400 Comments
I test the closed loop printer
http://v.youku.com/v_show/id_XMTUzODI0NDE0OA==.html
the printer can back the right position , After I draged the carrier to a wrong positon.
And this is the testing example of my 3D printer.
And this the open loop one.
The conclusion:
It same the well turned AnanasStepper 1.0 CAN avoid losing steps.
But there is some bad feature.For examples,there is over shoot ,because AnanasStepper 1.0 Use PI mathod ,So It is hard to get a very perfect performance.
So I begin to develop New version!
Then AnanasStepper 2.0 came to stage!!
