Run Raspberry With CAN bus(MCP2515)
A project log for AnanasStepper 2.0 - 3.0
Open Source CAN Bus Based Servo Stepper for Multi Axis Gang Control
graypillowGrayPillow 06/22/2017 at 03:050 Comments
Drive Raspberry with CAN.
It is recommended to use The lastest system of Raspberry!
As I tested, the max bitrate of CAN can be 500Khz.
Reference Material.
http://lnxpps.de/rpie/
https://www.raspberrypi.org/forums/viewtopic.php?t=141052
http://tiqni.com/raspberry-pi/can-bus-support-in-raspberry-pi
http://skpang.co.uk/blog/archives/1165
Some Problem and Answer:
https://raspberrypi.stackexchange.com/questions/51829/unable-to-bring-can-interface-up-on-raspberry-pi-3
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=155651&p=1023355#p1023355
