#11 - Making a small guitar effects processor with MAD and Teensy
A project log for MAD - Modular Audio Devices
A set of Eurorack modules to control synths, make custom MIDI-compatible interfaces and USB audio, powered by Teensy 3.6
michele-perlaMichele Perla 10/13/2017 at 17:120 Comments
I soldered an HI-Z module to test it, and after some ground issues I got it working; you can see in the video that the gain control is set to no gain, so it's acting as a voltage follower; increasing the signal gain using my Gibson SG sends the amp in saturation really easily, so I might have to modify its design. But still, the proto does its job as you can see in the video :)
