Cable Tester v1.2
A project log for Audio cable tester
The evolution of an XLR / Jack audio cable tester
borazsloborazslo 04/13/2017 at 22:250 Comments
The Cable Tester v1.0 had some serious issues. That tester could detect non-connected cables/lines but it had problems recognizing miss-connected / switched cables. So I have made a plan for the newer version with the help of @davedarko's comment.
Check out and test online the new circuit: https://circuits.io/circuits/4643590
Cable Tester Circuit v1.2
The new circuit needs a new box as well. But that is for another time.
