Hackaday.io Hackaday.io
Sign up Log in
IR Decoder
Decoded the infrared signals sent from a universal remote with the help of a certain PIC16F886 µ-controller and now it controls my lights.
curiousengineer22curious_engineer22
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
342 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
499
0
342
4
Team (1)
  • curiousengineer22curious_engineer22
Join this project's team
  • IR Decoder
hardware
completed project
microcontroller Pic16f886 infrared Microcontroller pic16f886; generic universal remote; ir sensor;
This project was created on 04/06/2017 and last updated 7 years ago.
Description
If you are looking for an extremely inexpensive way to decode infrared signals, well then look no further. By taking an IR sensor and hooking it up to an oscilloscope, I decoded the signals sent from a generic universal remote control. By counting the number of bits being sent it is easy to create a timer within the micro controller (PIC16F886) to determine if a '1' or '0' is being sent. By enabling the positive going trigger (PGT) as my start and NGT as my stop, I could time the pulses within the µ-controller using the interrupt and a pretty intense 'if' statement . I counted the pulses, plugged them into an array and then printed them to an LCD screen first in binary, then in hex (for spacial reasons of course). I then took it a step further and wired up a solid state relay so that I could control power directly from any wall socket from my pcb. By doing so, I can essentially control anything that is run from the standard 120AC 60 Hz power
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Creating a replacement for the Melnor timer, one that allows for easy timing of multiple valve units in a web interface.
Project Owner Contributor
Hacking the Melnor 53280 into an iOT Timer
laurentopialaurentopia
Automatically detects when a blower gate is opened and turns on the collector motor
Just Another Dust Collector Controller
jasonJason
This remote controller uses the gen4-uLCD-35DCT (125-8025) as the main interface for sending IR commands.
Universal Remote Control
4d-makers4D Makers
A generic control system for non-extreme chambers. If your growing mushrooms or you want to print exotic materials this project is for you.
Chamber Control Prototype
bobnetbobnet
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "IR Decoder", please tell us the reason.
Send message
Remove Member
