Raspbian, FlDigi and GQRX
A project log for 2m FSQ Beacon
Sounding beacon for FSQ digital mode on 2m band
scott-braggScott Bragg 04/30/2017 at 05:180 Comments
The version of fldigi on Raspbian Jessie is too old and does not have FSQ mode. You need to download it from here and compile it:
In addition to being an old version, GQRX in the Raspbian repos also did not work. However there is a binary installer that can be found here.
To connect these two up, you will need a loopback sound device. Add a line with 'snd-aloop' to /etc/modules
