Mounting the frame
06/18/2017 at 08:19 • 3 commentsThis weekend I finally found the time to cut, drill and screw the first parts of the frame.
Looks promising.
Finally the first results
06/06/2017 at 08:26 • 0 commentsThis weekend, I found the time to work on this project. The first aluminum parts are finished.
More pictures will follow.
The wheels
05/13/2017 at 10:04 • 0 commentsI will use 400mm wheelbarrow wheels for the go-kart. Now I have to find a solution to attach the brakes.
First aluminum profile
04/29/2017 at 18:42 • 0 commentsToday I found 2 aluminum profiles. They have a length of 2m. The dimensions are 40mm x 20mm x 2mm
Now I need to buy 2 profiles of 30mm x 30mm
Shock absorber, Brake discs and the H-Bridge parts
04/26/2017 at 12:01 • 0 commentsFinally the parts are here:
The motor and the first parts
04/09/2017 at 15:37 • 0 commentsFor the brake system I will use this Motor from an old project of mine A motor with a screw drive. It's very strong and fast enough for my ideaFor the controller, I will use an Arduino Nano and a breadboard for the hbridge.
Alain Mauer
