DC-DC Converter Ready
A project log for The 200W+ AA Battery Electric Bicycle
A 200W+ electric bicycle powered by a bank of regulated super capacitors that are charged by 10 AA batteries.
david-scholtenDavid Scholten 04/23/2017 at 12:500 Comments
Took some time today to focus on preparing the DC-DC converter for the bicycle.
It has a multitude of inputs and outputs, all relating to the operation of a "standard" electric bicycle. These features include a battery charging port, brake notification in, brake lights out, headlights, key start, battery in, motor out and throttle control:
Taking a peak at the other side it seems to be a standard DC-DC buck converter with a single transistor and a flywheel diode.
Cutting off the functions I don't need:
Sealing up the unit (only power, motor and throttle connections remain):
Electrical tape based water "proofing":
A test run of the motor:
