Shazam!
LCD done. I ported a PIC LCD library (a few routines for interfacing to 4 bit mode HD44780) to the LPC11C14. See the original here: http://blog.vinu.co.in/2011/06/4-bit-interfacing-of-16x2-lcd-display.html Thanks bud!
The ADC tested out well, the SD card is being written to, the UART works (hooked it up to my Bus Pirate, arrrrrr) the only thing left to do is make a cable between the car and the board and test it out. I am excite.
