Legs
A project log for Star Wars: BT-1 the Blastomech
BT-1 was introduced in the Star Wars Darth Vader comic books as a twisted mirror version of R2-D2. BT-1 is the first and only Blastomech.
kenneth-zabornyKenneth Zaborny 04/11/2017 at 14:210 Comments
I plan to 3d print all the leg details. I have a Flashforge Creator Pro. These files are available on the Astromech.net wiki. They're already sliced to print on small print beds.
The first leg cuts were rough but with a little trial and error I have a full set of legs.
The next step is gluing these together. They're just dry fit at the moment. I used a 3/8th wooden dowel as alignment pins. There's a sheet of aluminum cut into the ankle section for added support. I've seen images of cracked and broken droid ankles. This can lead to damaged droids or worse, injury to people around the droid.
