Android App - Bluetooth RGB Controller
Arduino Nano, HC-05 bluetooth module, and some super bright RGB LEDs!
Cool person in my Discord channel paid me to set up an RGB LED controller using parts he already had. So I got myself some Nanos, the HC-05 bluetooth module, some RGB LEDs, and downloaded Android Studio.
I'm amazed at how easy this stuff has been. I never really made the connection to the analog world. Digital signals were always handled for me by software.
Now I'm making wifi doorbells, bluetooth LEDs, and I plan to put a relay or servo on every appliance in the house.
There's nothing I can't do. Where's the brakes on this thing?
This project should be fairly straightforward. I plan to turn the results into a youtube tutorial. The costs are minimal and the know-how is basic.
I'm a teacher at heart- so I like to give back to the community that taught me!
I'll also whip up an ESP8266 version, using NodeMCU and espruino.
  • 1 × Arduino Nano Microcontroller
  • 1 × Super Bright RGB LED Common Anode
  • 1 × HC-05 Bluetooth Serial Module
  • 1 × Assorted Current Limiting Resistors 200-ish ohm, 330, 1k, 2k - There's a voltage divider somewhere
  • Arduino RGB now with Color Wheel!
    Trent Sterling05/03/2017 at 20:41 0 comments
    I still need to refactor this entire thing- but hey, it's working! I'd like to figure out TABS in Android Studio so that I can dedicate more screen space to settings and sliders. Right now everything is stupidly cramped into one screen.
    Friend of mine who started me on this RGB journey got a copy of both the Arduino and Android code. He's planning something with more LEDs with transistors and whatnot- using my code to get started.
    I'm looking forward to seeing what he puts together.
    I have a 16ft RGB LED strip in my living room, and I think it would be nice to use this as a controller. I can never find the remote!
  • Android Studio - Arduino RGB App UI
    Trent Sterling04/17/2017 at 03:01 0 comments
    Figured out how to do constraints with a bunch of trial and error..
    The UI editor drag-n-drop animations are super laggy and buggy. Undo feels wonky too. At least things are progressing along.
    Color Wheel looks fancy- but the simple RGB sliders are easier to dial in to exact values. I think I might end up liking Android Studio after I get used to the tools.
  • Getting Started
    Trent Sterling04/10/2017 at 18:10 0 comments
    Well I spent probably too much time soldering on my first set of headers. In comparison to some of the youtubers who got me interested in soldering - I did a poor job.
    I accidentally bought some very thick solder. I spent most of my time wicking it off!
    Also, I need to get some blue-tack or something to hold the headers in place.... Hot glue was a poor choice...
    (I'm a software guy stop laughing!)
    But hey- the connections are electrically sound! So I'm happy with it!
View all 3 project logs
Guy Fraser wrote 04/11/2017 at 15:39 point
Where are you sourcing the super-bright LEDs? And how do they compare to the bright neopixels? Also, I didn't notice any resistors in your screenshots or component list - most LEDs will burn out after prolonged use without a resistor to limit current.
Trent Sterling wrote 04/11/2017 at 15:45 point
I wish I could tell you that I waited for the long boat from China - but I picked up 100 of these LEDs from Amazon.
https://www.amazon.com/gp/product/B01C19ENFK/ref=od_aui_detailpages00?ie=UTF8&psc=1
There is a resistor on the red leg, as it is only 2.2v tolerant. The other channels are running off 3.3v (which is overdriving them just a little bit!)
EDIT: Yes - I'd say they compare pretty well to some NeoPixels! They don't look as cool though.
