maxwell_007.inoArduino code, updated to handle external sensors, consisting of a DHT-22, a CDS cell, and an IR photocell.ino - 6.01 kB - 09/19/2017 at 07:08 |
maxwell_data_17-09-2017.CSVData collected after installing external sensors. 17-09-2017 refers to the date the recording was copied from the memory card, in the evening.Comma-Separated Values - 556.35 kB - 09/19/2017 at 07:04 |
maxwell_005.inoOld version of the Arduino code. There's some unnecessary serial output in this version that I used for diagnostics.ino - 3.69 kB - 04/20/2017 at 19:19 |
maxwell_data_16_04_2017.CSVData collected from early field testing. The variables measured are (left to right) battery voltage (uncalibrated), solar panel voltage (not yet monitoring), light (uncalibrated), temperature (degrees centigrade), humidity (percentage), error code, and fan status.Comma-Separated Values - 302.28 kB - 04/16/2017 at 10:13 |
maxwell_data_05-04-2017.CSVData collected from early field testing. The variables measured are (left to right) battery voltage (uncalibrated), solar panel voltage (not yet monitoring), light (uncalibrated), temperature (degrees centigrade), humidity (percentage), error code, and fan status.Comma-Separated Values - 84.39 kB - 04/10/2017 at 18:48 |
