It started out as an airplane
A project log for Your Personal Flight Simulator
Take some off the shelf parts, some miscellaneous materials, and a couple of dead laptops and make a flight simulator
samernsamern 04/12/2017 at 01:410 Comments
I started this project as a simulator based on the fuselage of my homebuilt airplane. After that was done, I showcased it the NoVA Mini Maker Faire and it was a hit. I then ran into a space issue and ended up dismantling it. I donated the computer I had built for it and also gave the fuselage to a friend of mine for his project. I did keep the idea alive though....
