April 15, 2017 - Cardware construction of the instruction card
A project log for Brainwarp - Program entry panel
A design for a program entry panel that uses tiles for instruction input.
dr-cockroachDr. Cockroach 04/15/2017 at 19:042 Comments
This is the latest version that uses the #Cardware method of enclosing the instruction card. I also have found some ceramic magnets that have greater holding pressure and this results in a solid contact.
This card is wired for code 5 - Move pointer right one position
Yann Guidon / YGDES wrote 04/16/2017 at 17:08 point
Could you reduce the number of magnets ? I would have a strong one on the base and just metallic junk in the instruction cards...
Dr. Cockroach wrote 04/16/2017 at 18:43 point
Sure could and not a bad idea as there will be many cards :-) Thanks Yann :-)
