Them Modules...
A project log for YaMseK
Yet Another Modular Split Ergonomic Keyboard a custom 40-60% keyboard with a columnar+curved keyboard layout and an attached thumb-cluster
johschneiderJohSchneider 05/01/2017 at 17:360 Comments
a quick overview of the modules used (so far), which contribute to the 'M' in the projects name and are designed to support/simplify the (hand) wiring of the keyboard matrix
the I2C_bridge_primary
sits on the microcontroller side (which runs the firmware and does the USB stuff)
it's main features are
- I2C buffering (for long/unshielded wires)
- ESD protection
- current limiting
Order from OSH Park
Parts:
- TRRS phone-socket SJ-43514-SMT
- current-lim. IC: AP2553W6
- I2C Buffer P82B715
- ESD diodes VESD05a1
- 0805 resistors and capacitors
the I2C_bridge_secondary
sits on any of the slave devices (usually one/another keyboard half, but could be multiple other devices)
it's main duties are:
- I2C buffering
- ESD protection
Order from OSH Park
Parts:
- schottky diode SS14
the matrix_Attiny861a
mostly an breakout board for an attiny, with pads on the front to directly solder a ribbon-cable which spreads out to the handwired keyboard matrix
- ICSP contacts for reprogramming
- pads to solder a 4-wire ribbon cable to the device-internal i2c-bus (with the attiny running an i2c-slave firmware)
- an expansion header which can be fitted with an 2x6 micro-match connector to add more keys or use the ADC for an analog joystick
Order from OSH Park
Parts:
- micro-match socket 1-215460-2
- attiny 861a
the matrix_MCP23017
- a breakout board for the I2C port-expander
- with pads to directly solder a ribbon cable which spreads out to the keyboard matrix
- as well as a ribbon cable to the internal i2c bus
- 2x6 micro-match expansion header for additions to the keyboard-matrix
Order from OSH Park
Parts:
- MCP23017
