Charlieplexing explained @ http://en.wikipedia.org/wiki/Charlieplexing
PCB making procedure @ http://www.instructables.com/id/Making-A-Customized-Circuit-Board-Made-Easy/
SAVE WALTER WHITE @ http://www.savewalterwhite.com/
a blinking {romantic} heart built with a bunch of leds and a Atmel ATTiny85 to rules them w/ charlie. Everything mounted on a home made pcb!
just completed the new old schematic using true pre-builded avr atmel attiny85 component, with a 10KOhm resistor between VCC and RST pin.
this is the board:
i'm going to print my own PCB using etching solution and marker for minor corrections. Blue dashed wires are air-wires!
i'm sorry, i tried to design cool schematic with everything inside the heart but seems to much harder for me at the moment. I'm a totally newbie on design and printing pcb. I'm going for standard layout with resistor and ATTiny outside the heart
pcb copper, ferric clorhide, marker and leds will be come at home on tuesday, total spending 7 Euro + 3 Euro for shipping costs! yay!
Thanks to davedarko i managed to draw a new schematic, now ATTiny is placed in the center of the heart. Pin wirings were corrected and i put a 1Kohm R between RESET pin and VCC (give me some feedback, it is correct?)
i'm a newbie on designing schematics for my projects but i'm going to do my best! thanks to a commet here below i'm going to:
1- fix the wrong wiring on the reset pin of the attiny85
2- edit the pcb design to wrap attiny85 with red leds all around!
Can you post some pictures of your failed attempts? That could give away some points may be. Drawing it by hand sounds hard, since you have to mirror it etc.
It's better if you use the bottom layer (blue) for your board, since it will be on the bottom later.
i printed the design using a laser printer onto some plastic gross paper.. then i transferred the image onto the pcb using an iron.. but lines was not so marked
I've bought a laminating machine once I saw a cheap one. Using an iron you have to hold and press it really long and make sure that you really really heat it well. Were you able to use the markers to fill the lines? How did your printing file look?
Something in the way like this. Do you have a 10cm*8cm copper board? You would then have to print this normal and etch it. I took your design and couldn't resist doing it the way I mentioned before, placing the attiny inside and placing the LEDs so they all face the same direction. I've used the blue layer and finally exported a picture of it and the via layers in monochrome. You would have to etch it and drill the holes and put the parts in.
By the way, have you tested your circuit on a breadboard before or have the software ready?
https://www.dropbox.com/sh/x15jer8da1q57w1/AACz_oiydWPE7JYQy5YpuSRSa?dl=0
I made one like this for v-day. Used 20 LEDs and wrote firmware to actualy allows 8-bit brightness on each simultaneously. I can share the code with you if you'd like.
i didn't complete it! i committed various mistakes during pcb etching procedure and i gave up!! actually if someone can share any tip about how to print design and impress it onto the pcb i will be so glad..
