just completed the new old schematic using true pre-builded avr atmel attiny85 component, with a 10KOhm resistor between VCC and RST pin.
this is the board:
i'm going to print my own PCB using etching solution and marker for minor corrections. Blue dashed wires are air-wires!
I'm still interested to see how this turned out ;) And I spotted a lose wire on your design between the reset button and the 10k pull-up resistor.
