Arduino PWM LED dimmer - 6x10W LED
http://geek.adachsoft.com/home/article/id/16/n/Arduino-PWM-LED-dimmer-6x10W-LED/refid/hd
LED control using Arduino with PWM
In this tutorial I will show you how to make LED control using Arduino with PWM. For dimming control I will use an encoder. So it will also be a tutorial on how to use the encoder in Arduino projects. In the project I use 6 LEDs each 10W, as a power source I will use a 14.4V battery from a cordless drill.
Ulysse wrote 04/15/2017 at 21:27 point
" lumière! "
