Status Quo
A project log for 3 Node Raspberry Pi Cluster
I try to build a 3 Node Raspberry Pi Cluster to teaching myself how cluster PCs work.
Tobias W.Tobias W. 07/25/2014 at 13:070 Comments
I got all three Pi's mounted on the base plate drilled the holes for most of the power cables. Whats waisting my time right now is the fact that I don't got all the tools I need to work with metal but in the next 24 to 48 hours I should be able to drill the last holes and bend everything into shape. If all that is done I can focus on the wiring and the power setup of the case.
