Hacking a Cheap Wifi Outlet
Back to overview
Others have shown cheap Chinese WiFi Outlets can be hacked. Time to see how hard it is. (Hint: not very)
Trevor Daniel wrote 03/15/2018 at 18:08 point
Wow! Thank you so much for taking the time to write this up! I have just converted my Lingan SWA1 Plugs over to MQTT so I can control them from Node-Red.
robbalmbra wrote 08/04/2017 at 09:40 point
could I use a USB TTL Serial Cables to access terminal? it has 3.3v supply as well
