Arduino Splash Resistant Toilet Foamer
Soothing Silent Scentless Relief
Splash back is a scourge of our archaic crapping technology. As alternative to perching several feet above the bowl comes the Arduino Toilet Foamer -- permitting a user to create a more splash-resistant, sanitary and refreshing bowl environment.
Bowels a-grumblin'? Activate the Arduino Toilet Foamer from your phone app -- triggering the Arduino relay(s) for the aerator and solenoid value which injects a specified dosage of glycerin and soap in to the bowl water where it becomes en-frothed by gyrating bubbling action. Exhume waste as necessary.
Update (33-017)
A user in the residence I currently occupy has taken such a liking to the prototype that there is demand for an updated more efficient version -- now in the works.
Shd be noted that the scent event in the video was purely theatrical -- when in fact after much use, the project was found to reduce scent exponentially -- giving a refreshing odor relative to the detergent utilized. Do they make Red Vines dish detergent?
  • 1 × Arduino Uno
  • 1 × Fish Tank Aerator
  • 1 × 1/8ID 1/4OD Vinyl Tube
  • 2 × TIP120
  • 2 × 4001 Diode
  • 2 × 5V Relay
  • 1 × 1/8 Tee for Two
  • 1 × 12V Solenoid Valve
  • 1 × Plastic Bottle?
  • 1 × 1/8 Check Valve (No Filter)
View all 19 components
  • ​Bubble Recipe
    VijeMiller6 days ago 0 comments
    Soap 4:1 Glycerin
    Pre-mix with out much gyration.
    Add water shd your build require more fluidity.
    Add dye or scent (bacon?) to enhance your rather boring redundant defecating experience.
    You will notice that a good deal of soap remains in the bowl following flush, permitting more soap per bowl per bub.
  • ​Notations
    VijeMiller04/18/2017 at 20:56 0 comments
    1. Advice to straighten vinyl tubing is to boil water and quickly submerge. Dry in the desired angle. Cure shorter pieces by submerging in cold water.
    2. Do not use concentrated liquid dish or hand soap -- aka "Ultra" brand.
    3. Would-a could-a shd-a larger aerator, (2) more valves and a variant bubbler to increase foaming efficiency. Had considered a lower and drop per awareness that foam lasts longer than anticipated thus not immediately required per use.
    4. Hypothetically, water reduction could be obtained by foaming water in a toilet. Elon Musk, you can send a check or money order to...
  • Foamy Codey
    VijeMiller04/18/2017 at 03:48 0 comments
    // Toilet Foamer
    // VijeMiller
    // TVMiller.com
    // Neopixel
    #include <Adafruit_NeoPixel.h>
    #define PINSTRIP 10
    Adafruit_NeoPixel strip = Adafruit_NeoPixel(5, PINSTRIP, NEO_GRB + NEO_KHZ800);
    // Aerator
    int aerator = 7;
    // Valve
    int valve = 8;
    void setup() {
      Serial.begin(9600);
      // Pin Values
      pinMode(aerator, OUTPUT);
      pinMode(valve, OUTPUT);
      // Load Neopixel
      strip.begin();
      strip.show();
      digitalWrite(aerator, LOW);
      digitalWrite(valve, LOW);
    void loop() {
      // Listen
      if (Serial.available() > 0)
        digitalWrite(aerator, HIGH);
        // Prime Soap Container
        delay(3000);
        digitalWrite(valve, HIGH);
        // FOR to Delay w/ LED
        for (int i = 0; i < 15; i++) {
          colorWipe(strip.Color(255, 0, 0), 70);
          colorWipe(strip.Color(0, 255, 0), 70);
          colorWipe(strip.Color(0, 0, 255), 70);
        for (int i = 0; i < 500; i++) {
    void colorWipe(uint32_t c, uint8_t wait) {
      for (uint16_t i = 0; i < strip.numPixels(); i++) {
        strip.setPixelColor(i, c);
        strip.show();
        delay(wait);
View all 3 project logs
  • 1
View all instructions
Gabriel wrote 6 days ago point
Great project.  You must offer it with a adjustable foaming timer though. Too much foam and your squirrel snacks and/or 1 eyed snakes might end up taking an unwanted bubble bath.
VijeMiller wrote 5 days ago point
Consider it a jacuzzi bidet -- a bits n' pieces spa. There is a for numeral limit in the script to prevent being bowled over. Thx!
