Video of the modular private smartphone prototype
A project log for Modular private smartphone
Earth friendly smartphone that you can upgrade or change a broken part without buying a new smartphone, minimizing waste.
immaimma 04/30/2017 at 21:450 Comments
In this video I show a prototype of the modular private smartphone, with the following parts:
· Manga screen.
· Raspberry Pi 2 B (in the next prototype the pi zero w will be used).
· Fona 2G (in the next prototype the Fona 3G will be used).
Together with Gerard we made a software to make/receive calls and read/send SMS that you can connect directly to the raspberry pi (without the need of an arduino)
The software can be downloaded from the following link:
Modular private smartphone software
The python file and the png images need to be in the same folder.
For the software to run the following commands need to be used in the terminal:
sudo apt-get install python-serial
sudo apt-get install python-tools
sudo apt-get install python-qt
sudo chmod 777 /dev/ttyAMA0
Open modular_private_smartphone_v0.4.0.py with the python IDLE (using python 2.7) and run the module.
