First Motor Test!
A project log for The UnbreakaBLE Micro Drone
Use any Bluetooth 4.0(BLE) device to control this agile little modular drone.
anshul-sanamvenkataAnshul Sanamvenkata 07/24/2017 at 05:130 Comments
First motor test has been a success!
I tested each of the six motor outputs and all of them are working. In the video, I have a simple PWM program running that increases the speed to 40% of the motor's fill thrust, and then decreases it to zero. You can hear the motor changing speed in the video. it never fully stops because there is a only a tiny delay between zero, and the speed increasing again.
