Flashing in Arduino / Energia IDE Complete
A project log for Roadrunner (the Arduino-Tiva)
An Arduino clone based on a TI's Tiva TM4C123G (An 80Mhz ARM M4F with USB OTG)
JacobJacob 06/16/2017 at 19:412 Comments
I've just completed building, integrating and testing the custom DFU programmer in doth Arduino and Energia. I'll publish the board manager JSON file and support packages to github shortly. I'm pleased with how relatively smooth the integration went. I've learned a lot about integrating custom board support packages into Arduino along the way and will do a write about the process soon since I found it convoluted at first myself.
The only thing left to do before releasing this into the wild is to add Linux support and do some minor fixes to the board layout.
If this was crowdfunded for small run of 100 boards, probably priced at $30, would you be in?
Ghostronics wrote 06/17/2017 at 21:57 point
I would be in. $30 dollars is a reasonable price. Looking forward to your complete project and hoping that you will win the prize of the best product.
Jacob wrote 06/27/2017 at 21:42 point
Thanks for the support! It would be nice to win best product prize but honestly I think my chances are slim. Still, I'm going to work this project to "completion" because it's really a learning experience for myself. First time designing a real board from the ground up and all.
