Completed Initial Pin Mapping
A project log for Roadrunner (the Arduino-Tiva)
An Arduino clone based on a TI's Tiva TM4C123G (An 80Mhz ARM M4F with USB OTG)
jacobJacob 04/25/2017 at 23:230 Comments
I just completed the first pass through the pin map file, "pins_energia.h". The next step is to test it on LaunchPad board to see if all pins were successfully remapped.
I'm also beginning to compile a list of hardware changes for the next revision.
