Flashing in Windows - Progress
A project log for Roadrunner (the Arduino-Tiva)
An Arduino clone based on a TI's Tiva TM4C123G (An 80Mhz ARM M4F with USB OTG)
jacobJacob 06/15/2017 at 04:350 Comments
I've almost completed putting together the program to initiate DFU mode and flash the board from within Arduino / Energia. It's pieced together from source code provided by TI in their TivaWare sdk. This will be a Windows only flashing tool customized to the boot loader process of this particular board. I've not begun the Linux side yet, but my research tells me that it will be a much easier task. I believe "dfu-util" will work for it with only minor modifications.
