Project status:
I have a working version of the architecture simulated in VHDL. It is synthesizable, and I have downloaded it to an Artix-7 development board - the Digilent Cmod. I have a few simple programs running with a UART interface. I have a bootloader/monitor running so I can load programs over the UART. I've written a simple assembler to generate machine code I can send to the bootloader. I've finished a schematic and layout for making a PCB.
Primary project goals:
- Implements only one instruction - move
- Can be built using a minimal number of simple DIP components (74xx TTL circuitry).
- All components are active. No obsolete or hard-to-find components. All components in stock at popular distributors.
- Useful - it needs to be able to run programs in a short amount of time.
Secondary project goals:
- Useful input mechanism. I expect a set of DIP switches for the input, but I'd prefer something more useful like a UART port or maybe a keyboard.
- Useful output mechanism. I could do a simple LED numeric display, but I'd prefer something more useful like a UART or at least a 4x20 character display. Perhaps I'd even do a video memory with a separate display.
- Easy and natural loading of programs. I'd prefer not to have a roundabout way to load programs into memory. Perhaps even use the above UART to send programs.
- Easily expandable for more memory. I'd like to be able to load very large programs.
- Write/adapt a compiler/assembler. I'd like to be able to take existing programs and compile them to run on the computer. This would probably be the last thing I do considering the complexity.
PCB Assembly Plan: bold is completed
- Clock circuit with single-step mode and Reset
- Control state machine with AND/NOT gates and control LEDs
- Program counter Low and High with Memory Address Buffers and address LEDs
- Control Decoding
- Instruction ROM and data bus LEDs
- Src/Dst Hi/Lo registers with data buffers and Src/Dst decoders
- Source Hold Register
- Program counter Temp register and data buffers
- ALU A
- ALU '171 chips
- ALU result reg
- AEB/Carry FFs/buffers
- Pointer address registers
- UART
- RAM
2-Zons
kaimac
Hi Justin,
Step back and relook at what a TTA is:
MOV [DST], [SRC]
The machine cycles are:
Fetch SRC (address)
Fetch Data from [SCR]
Fetch DST (address)
Deposit Data to [DST]
This is what the timing diagram of the control signal looks like for the above machine cycle:
Sorry there is no load immediate but your assembler can store a constant for you to simulate a load immediate.
For indirect addressing (pointer to pointer moves, you will need these at some point), you will need self modifying code.
That is for another time.
If your happy with the above the decoder logic is four chips including the clock.
AlanX
