VHDL coming along
A project log for One-instruction TTL Computer
A breadboard-able computer which uses only a single instruction - MOVE
Justin DavisJustin Davis 04/23/2017 at 22:381 Comment
So I put together my RAM module in VHDL modeled after a generic SRAM. I was thinking of using an AS6C62256 from Alliance Memory. After a good bit of slugging it out with my VHDL code, I have a program counter connected to two RAM modules with registers on their outputs for the Source and Destination locations. I have a load register, ALU A register, and my ALU all hooked up to my data bus.
So I have my testbench loading a 3 line test code into the RAM which 1) writes a constant into the load register, 2) transfers from the load register into the ALU A register, and 3) adds the value in the ALU A register to the load register. And it works! (maybe a glitch or two still) It's a good start. I'm doing one-line VHDL address decoding for now, but I imagine I will eventually put them into EEPROMs. Next I'll finish the ALU output register and fix some glitches.
Yann Guidon / YGDES wrote 04/23/2017 at 23:22 point
very nice !
