Mostly working (mostly)
A project log for One-instruction TTL Computer
A breadboard-able computer which uses only a single instruction - MOVE
Justin DavisJustin Davis 12/14/2017 at 18:420 Comments
I have all of the CPU working now with the exception of the UART.  My BREAK command is working, which makes it much easier to check out the functions.  I just run the clock fast until it hits the BREAK command, and then I can step through the next instruction.  Now, I just need to get the UART working so I can load programs over that port to the RAM directly.  So close!
