PCBs shipped!
A project log for One-instruction TTL Computer
A breadboard-able computer which uses only a single instruction - MOVE
justin-davisJustin Davis 11/16/2017 at 21:030 Comments
PCBs are shipping from EasyEDA and will arrive probably Monday.  I have also received all components.  I have also updated my FPGA design to match the PCB, so I should be able to run the same software on both platforms.  This will hopefully help me to debug any issues with the PCB.  I have my assembly procedure listed on the project details page, and I plan to test as I go to make sure each part works as expected before I build the next part.
I also have my EEPROM programmer code all working.  So I can generate an Intel HEX file to download to the EEPROMs for each of my three EEPROMs in the design.  ALL SET TO BUILD!
