So far so good
A project log for One-instruction TTL Computer
A breadboard-able computer which uses only a single instruction - MOVE
justin-davisJustin Davis 11/22/2017 at 16:300 Comments
Got the power up and running.  The clock is on, but forgot to order a couple chips.  I did not go through my BOM closely enough.  So I'm ordering some today and hopefully they will be here soon.  In the meantime I've put on other time consuming parts like all my bypass capacitors and surface mount resistors.  They need to go on first anyway so I don't melt my sockets.
