Please teach me hackin anyone
step 1: disassemble anything that catches your eye
step 2: reassemble mess from step 1. if non-functional, continue to step 1
step 3: reassemble to yield new functionality. if non-functional continue to step 3
end
you can't just learn a lifestyle...HACKING IS A LIFESTYLE!!!
in my opinion, u should learn the language first.. such as html,php,phyton etc.
and if u want to go straight, just learn the ip, without an ip, we cant see the target.
good luck ^^
What is hacking ?
Nobody asking for help to become a hacker has even told what it means.
It is like "I wanna be cool", you can't learn an attitude...
Part of a hacker is self taught, being able to find stuff on your own. Without that drive, motivation and resourcefulness, you don't have the right stuff for this.
it is not entirely hardware hacking here, but all "hacking" requires hardware, wetware, or both. The equation for the answer to everything is: datasheet(s) + creative thinking + 42 + some social understanding
The movies are necessary (and books), and even if your social understanding isn't cognizant, it is inherent, and will be defined by your actions.
First you gotta watch Hackers (1995) and Sneakers(1992). They should tell you everything you need to know to get started.
After you've practiced enough on the skateboard and rollerblades, watch them again. There are lots of hidden details that you might to pick up at first. Maybe after seventh or eighth viewings.
Hope that helps!
Indeed. RISC architecture is gonna change everything.
Hey. This platform is thought for all kinds of hardware hacking - meaning stuff that involves using a soldering Iron to make things work / work differently. This is not a community of computer guys that will crack passwords or steal software (although some might be able to do this, but that is not the point). We hack devices with software and hardware, not people.
A general tip for the web: don't ask others to do stuff for you! Read, learn, ask specific questions that will help you get along with your projects.
Any worthwhile website for those kind of stuff are typically by invite only or behind password. They don't want to bother with the wanna-be.
You're right but haven't done that before not a lil bit so i'm asking to teace me lil bit you know A student can't study books without a teacher :) i'm just asking for a lil bit help!
I suggest searching on google. Like "Learn hacking pdf"
And start learning programming languages like python, ruby, etc. 'cause that's what I learned in google.
just focus on studying pdf's.
Hope that helps☺
