Making and transfering the decal (Thermal)
A project log for Toner Transfer Decals
Using Toner Transfer to make project box graphics.
hacker404Hacker404 04/21/2017 at 13:480 Comments
I have one of these -
Well mine is *like* this *but* it's over 25 years old and all the printing on the front panel is faded or scratched off.
I have been wanting to try to transfer color toner onto surfaces other than PCBs and this is my opportunity.
There will be some other MODs along the way. I want to change the front panel banana sockets to the safety type sockets so I can use any test leads that I have here.
As you can see, I drilled out the banana socket holes to fit the larger sockets -
And, well, um, oops! I am too used to reversing imaged for PCBs. I scrapped this and started over.
The parts of circle around the holes will be covered over by the new parts.
The electronics inside was still in very good condition. I made this from a kit over 25 years ago -
Tomorrow I will spray paint the panel with clear acrylic and re-assemble the unit.
This is more or less a proof of concept. The panel steel coated with black plastic that I have painted white to contrast the toner.
I am thermally transferring the toner with a laminator. The next test will be to transfer to plastic chemically using a mix of IPA and acetone.
I will write another log when I finish this (hopefully) tomorrow.
