Just released Visuino and Visuino Pro - Graphical Development for Arduino - 8_0_0_72 with Canaduino 500, Arduino Portenta H7, Seeeduino Wio Terminal Support, Faster IDE, and much more...
A project log for Visuino
Graphical Development Environment for Arduino controller type boards
boian-mitovBoian Mitov 04/12/2022 at 16:339 Comments
Just released Visuino and Visuino Pro version 8_0_0_72
qtron wrote 04/22/2023 at 14:01 point
again,
huh, my post disappeared! i'll start again,, i'd like to know if its better than Ardublocks? & am not sure re using a graphical package with no knowledge of programming.. to set up a 'sketch' one needs to know which blocks & when to use them / or not etc. & if the prog involves much more than flashing a LED or Hello World, etc, surely U need the concepts to know how to approach  a proposed solution , .... am sure U know what i mean
qtron wrote 04/22/2023 at 12:30 point
is it better than ardublocks ?.. it occurs to me its one thing to glue various blocks together and quite another when U need the f/w to do something that U are not sure how to implement in the first place! Having trouble phrasing this, but u probably know what i mean..
Boian Mitov wrote 04/22/2023 at 14:49 point
It is best to download and try the free version ;-) . Visuino is completely different concept that Ardublocks ;-) . It is a whole different ball game ;-)
qtron wrote 04/22/2023 at 02:41 point
and the all up real $cost? pls!
Boian Mitov wrote 04/22/2023 at 04:03 point
There is free version, there is a standard version for $39 and there is a Professional version for $199.
Boian Mitov wrote 04/22/2023 at 14:48 point
You can use the free version for fair number of projects, so it depends on the complexity of the projects.
qtron wrote 04/20/2023 at 13:41 point
where is it??
Boian Mitov wrote 04/22/2023 at 02:35 point
You can download from www.visuino.com :-)
