1.5" SSD1351 OLED Breakout
This is a breakout board for a 1.5" color OLED with an SSD1351 driver. All of the pins are broken out for ease of prototyping.
Who doesn't love OLED's? Their relatively low power requirements as well as vibrant color displays are alluring to the hacker. While working on a few projects recently I had the need to interface with one of these OLED displays. There didn't seem to be any breakout boards that broke out the parallel interface pins of the controller, so I decided to make my own.
Scouring the internet for a decent OLED display, I came across this one from buydisplay.com. It's a 128x128 RGB display, with 1.5" diagonal measurement. The controller, SSD1351, supports a 8, 16, or 18 bit parallel interface, as well as SPI for communications. It seemed perfect for the projects I had in mind. Most breakout boards out there only take advantage of the SPI pins of the controller, and at least one of my projects would require access to the parallel interface, so I decided to just build my own board to suite my needs. Hopefully someone else finds it useful.
Adobe Portable Document Format - 39.40 kB - 04/23/2017 at 14:23
Preview
Download
  • Boards in and tested!
    Jon Thomasson01/31/2018 at 16:00 0 comments
    Got the boards back from oshpark about a month ago, but had a chance recently to assemble. After tying BS0 and BS1 to ground to enable SPI, I tested the OLED with the adafruit  SSD1351 driver library: here. Here's the result:
    And here's a look at the back:
View project log
deʃhipu wrote 01/31/2018 at 16:09 point
Wow, that's much fewer components than I expected! That boost converter looks sweet.
