I will discuss here all the parts of the project:
Turbine: do you think Tesla turbine is the most efficent solution in this application?
Tank design: how much pressure can it handle? Is the 1/8valve able to refill it? how much does it last? how much energy is produced?
Added electronics: Is an extra circuit after the dc motor necessary? What should it feature?
