Arduino datalogger with microSD card
A simple-to-use and easy-to-assemble data logger with Arduino micro and a microSD card
If you are facing the need of reading and storing sensor data (analog and digital signals) and do not want to spend a lot of money on an off-the-shelf data logger, I may have the solution for you.
Based on my own need for a simple and cheap system that can store analog data from various sensors (mainly 0-5v ones), I have developed an Arduino-micro-based datalogger that stores data to an on-board microSD card.
This is how it works:
1- Insert a microSD card on the slot (if you don't, the red LED will lit and nothing else can be done),
2- Connect analog or digital sensors (up to 5V max) to the 4 analog inputs and 1 digital (interrupt) input,
3- Supply 5V to the system, either from the USB @ Arduino Micro or the specific blue connector on the board,
4- Press the green button; the data will be logged into the microSD card on '.csv' format, from time to time (adjustable on the Arduino code),
5- The system will log data for as long as there is power supplied.
Here is an overview of the system; why I made it and how it works:
The full explanation, code and schematics is hosted on my personal blog:
http://fritzenmaker.blogspot.com.br/2017/04/arduino-based-datalogger.html
Registrador_de_dados_Fritzen_r00.ino
Arduino (.ino) code for the Arduino Micro
ino - 4.34 kB - 04/23/2017 at 22:21
Download
diagrama_esquematico.fzz
Schematic diagram (in Fritzing)
fzz - 12.50 kB - 04/23/2017 at 22:20
Download
  • 1 × Arduino Micro development board
  • 1 × Card reader (microSD) I used the one from Adafruit
  • 1 × MicroSD card (up to 4Gb) Any speed class
  • 2 × LED 5mm, any color
  • 4 × Screw-tipe through-hole 5,08mm connectors Two pins each
View all 8 components
View all 3 instructions
