• The App is running
    CF12/05/2019 at 20:07 2 comments
  • First running prototype
    CF05/15/2019 at 17:59 2 comments
    The first prototype with 8 double motors is running :-D
  • PCBs
    CF02/10/2019 at 21:31 1 comment
  • New PCBs
    CF11/23/2018 at 22:44 9 comments
    We are still working on the project. The new PCBs are running quite well. So a first prototype might be coming in the next weeks.
    We are now fixed with four steppers for each PCB. So each bigger clock should have a horizontal number of individual clocks, which can be divided by four. For the smallest version of 24 clocks it fits perfectly and for any bigger one this shouldn't also be a problem.
  • Main PCB and test run
    CF03/25/2018 at 10:08 0 comments
    Only a short update this time. We are spending the most time on writing the code and are close to the first test of the bus system. The main PCB is also ready. It includes the RTC and an ESP to control everything via wireless connection.
  • New concept, new PCBs
    CF11/01/2017 at 09:25 1 comment
    We did a lot of testing different motors, drivers and other things in the last weeks and ended up here. The new concept is running four X40 steppers by two X12.017 drivers by one STM32. The PCB can be cut to just three motors, if necessary. It measures just 40x3cm. The "clocks" will have a diameter of 12cm seperated by 5mm.
  • First Test PCBs
    CF05/28/2017 at 07:36 2 comments
    The first test PCBs arrived just recently. Everything is soldered for the first run. The gears fit quite well. Now is the time for beginning with the firmware.
  • Combining two X27 steppers
    CF05/23/2017 at 18:21 0 comments
    The first test parts using the X27 steppers are finished. I'm currently waiting for the first test PCBs. All parts can be directly soldered to the PCB as boards. As soon as the first board is finished, I'll upload some new pictures.
  • Reference
    CF04/24/2017 at 19:07 0 comments
    How to reference all the different steppers automatically? We had different ideas but the best solution so far seams to be small magnets and Hall detectors.
    We used very small magnets of 1x2mm in size. These were glued directly at or into the gears of the tested steppers.
    At the Sonceboz stepper it was pretty easy. Only two little holes have to been drilled and the magnets could be installed.
    In the housing of the stepper was enough space for adding the Hall detectors.
    The reference detection works pretty well.
    Adding all the parts to the VID29-05 was much more difficult even if the housing itself is bigger. Here it runs fine in about 90% of the test, but since we decided to use another stepper there was no further need of improvement.
  • Stepper
    CF04/24/2017 at 18:58 0 comments
    So where to start at this big project? The first experiments were performed with different steppers to get some experiences, which are suitable for this clock.
    We started with the Sonceboz 6407 stepper, which has two concentric shafts and looks very usable for this project. However the price of the motor, even when buying 125 pieces (around 27€ each plus taxes) was way to much.
    Another test was performed with the VID29-05 (or the clone BKA30D-R5), which you can get for less than $4 at Alibaba. This motor uses many gears to connect the two individual steppers to one shaft. This leads to an enormous increase of annoying sound while running. Even one stepper is to loud for my personal feeling. So, no chance for the VID29-05.
    The next attempt will be with two X27 steppers, connected by two external gears (probably laser cut) to one shaft. The motor costs around $1,50 and the construction is much similar to the Sonceboz 6407.
