OnoESC Case Mock-up
A project log for OnoESC 32-bit 30A ESC
The OnoESC is a 32-bit 30A 3S sensor-less brush-less motor controller that is Arduino Zero compatible.
colton-blackColton Black 05/11/2017 at 20:360 Comments
I did a mock-up of a potential case design.
I also made some small changes to the design such as a cutout USB connector (for ruggedness and smaller vertical profile) and the addition of a NTC thermistor next to the FETs.
