Hackaday.io Hackaday.io
Sign up Log in
LED Diodes Debugger Shield for Arduino
Small shield is for Arduino Debugging purposes! Its easy! Plug it in Arduino header and check your digital outputs.
owl-labsOwl Labs
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
164 followers
  • Description
  • Details
  • Files 0
  • Components 1
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
442
1
164
7
Team (1)
  • owl-labsOwl Labs
Join this project's team
  • You can buy it here!
completed project
hardware
arduino debugg Shield
Related lists
Projects using OSHpark boards
projects using the purple PCBs
This project was created on 04/25/2017 and last updated 8 years ago.
Description
What is "LED Diodes Debugger Shield"? This is unique super small digital outputs debugger board intended for Arduino users. It can make your life easy when working with digital outputs. You just need to plug it in your Arduino headers and you can easily check what digital output is HIGH and which one is LOW! Why did we make it? We made this board for testing purposes when working with digital outputs and inputs. It can show which pin is powered so we can double check our code or hardware if something is not working properly. What makes it special? This debugger board is actually hardware debugger. You can check your software or your hardware with it. It has pins where you can solder wires and customize your Debugger boards to fit your purposes.
Details
Components
  • 1 × Arduino Uno or Mega 2560 Compatible for Uno and Mega 2560 and it will cover digital pins
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
oshpark wrote 06/12/2017 at 06:53 • point
Great idea!
trying to match the classic Arduino footprint with an ESP-12E/F, PCF8574 port expander and a 4051 as an analog demultiplexer - for fun
Project Owner Contributor
ESP8266 board with classic Arduino footprint
davedarkodavedarko
Let's Shrink Arduino Projects, Robotics and Automation You all did with Arduino UNO. Now There is Shrinkified Version Here!
BABYDUINO: SHRINKIFY YOUR ARDUINO PROJECTS!!
patel-darshilPatel Darshil
The 2016 Hackaday Prize
with Arduino and beyond. . .
Explore M3
sandeep-patilSandeep Patil
The Arduino Zero programmer/board
$1 RDNO 0
daniel-sikarDaniel Sikar
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "LED Diodes Debugger Shield for Arduino", please tell us the reason.
Send message
Remove Member
