Motor Mount
A project log for RoadRunner - Powered Running Stroller
Mobility for families to enable active lifestyles
andrew-clinkAndrew Clink 04/27/2017 at 21:150 Comments
With all the previous discussion done, the motor mount is largely specified for us. It has a several deductive requirements. The motor mount must:
There are also a few requirements that follow to make the design robust:
In order to not interfere with the front wheel mounting tubes, we need the motor mount to be rather skinny, but not bend. We can accomplish this by using 16GA steel with a reenforcing bend at the top. This design could be stamped in one operation, lending to cheap manufacturing.
This is actually the second iteration of the mount. Testing so far has shown almost no belt slip even with high transient torques (when a PID value may have been typo'd) and low static drag when the motor is off.
Prototype
