Fan.stl
A quick fan to mount on the motor. - Center bore may need to be reamed to 14mm - Mounting bolts drilled to a bit over 3mm and countersunk depending on what hardware you have on hand :)
Standard Tesselated Geometry -
2.63 MB -
05/03/2017 at 23:33
