At last, all boards done, all seem to function properly.
Here is an overview of all boards for this project:
There was no way to place all circuitry for multiplexor on a single board, so I decided to extend it by one small board. As T-buffers occupy only half of this board, I placed some input capability. So the small board contains group of 4 tri-state buffers with common enable, which are enabling first nybble (most significant one) to the bus.
On the big board there are three groups of four tri-state buffers with common enable. Also two small circuits -- one is group of four invertors, which invert bus value. They are needed because t-buffers have inverted output.
Also there are four 2-NAND gates which are part of decoder.
Below the two boards of multiplexor connected together:
Part count:
part name | small board | big board |
2n2222a transistors | 20 | 68 |
1n3138 diodes | 8 | 36 |
red LEDs | 8 | 32 |
10k resistors | 24 | 32 |
20k resistors | 8 | 32 |
47k resistors | 8 | 32 |
dpdt switch | 1
DIP 8x spst switch | 2
pin header 4p | 4
Total parts: | 83 | 232 |
Also one 5*7cm and and one 7*9cm perfboards, and wires, of course.
