TM4C123GH6PM - SBL
Serial boot loader
Serial boot loader
I never got dfuprog.exe to work for me, so I used the LM flash util instead. I think that I could have probably accomplished the same thing with CCS as well.
SW-TM4C-SBL.z02
get all the files for SBL
z02 - 25.00 MB - 04/27/2017 at 00:02
Download
SW-TM4C-SBL.z01
z01 - 25.00 MB - 04/27/2017 at 00:01
Download
SW-TM4C-SBL.zip
This is the download from ti, repackaged for upload on hackaday.
Zip Archive - 13.29 MB - 04/27/2017 at 00:01
Download
usb_dev_sbl_ti.bin
original bin from ti install
octet-stream - 15.98 kB - 04/26/2017 at 23:55
Download
usb_dev_sbl_4.26.17_debug.bin
Using TivaWare C Series 2.1.4.178, TI v5.2.7
octet-stream - 16.25 kB - 04/26/2017 at 23:54
Download
View all 6 files
davedarko wrote 04/27/2017 at 05:36 point
dfuprog, hm that sounds awfully familiar. When I started my cartridge programmer, I had used dfu on an erased avr chip, unaware that it actually needs a dfu firmware on it to work in the first place :D next mistake was that I would need to dfu erase first, then prog over dfu. That took me a while as well to figure out.
jlbrian7 wrote 04/27/2017 at 13:41 point
I get what you are saying.  That was one of the first questions I tried to resolve, however, there was definitely a voltage issue on the chip as well.  I think that I may have got solder somewhere it should not have been, not enough to create a dead short, but still making contact where it shouldn't have been.
I have been running fast and loose with the whole design/build process for this board, as I wanted to get something together to show proof of concept before the end of the semester, and I did manage to 'fail fast',  but it doesn't seem to be catastrophic.  There are a lot of things going right,  I just need to run the problems to ground.
I think I will have some time this weekend to nail down the firmware flashing process in a more controlled way, and will get it up on this project page.
davedarko wrote 04/27/2017 at 16:00 point
Good luck! :)
