Bluetooth Module Mounting
A project log for Toy Claw Machine
Full size Claw machine made from misc. parts.
willbadenwillbaden 01/17/2015 at 22:340 Comments
Got around to mounting the Bluetooth module inside of the controller box. The board was soldered up (as seen in a prior log) and the HC06 was only mechanically held to the main board via its electrical connections. This proved to be too flimsy. So an angled aluminum bracket was made to support the HC06. This can be seen below:
Here is an overview of where the Bluetooth module is located within the controller box:
