Mechanical Prototype
A project log for Smart Antenna Tracker
An antenna tracker that adjusts for real-time changes in location, tilt & heading. It replaces a 915MHz 3DR ground radio module.
brandonBrandon 07/06/2015 at 17:480 Comments
I have made a wood prototype. The horizontal bar will be cut to length and a counter balance will be added once I get antennas. Now I will begin work on adapting the gimbal controller to fit the application.
