I used the dockstation to find a pin on the MB from where i could turn it on and off. Sadly it only works with the MB on it. so after some trial and error i found the pins to turn it on and off and get the state of the machine. All of this because i wanted to spare the amount of the daughter board with the power button.
I didn't destroyed anything, just modifyied it.
Important features :
- State of the MB trougth an opto-isolator
- Turn on/off trougth an opto-isolator
- Front USB
- The arduino is powered by the tv so it doesn't stay on when the tv is off. the downside is that i have to first power off the player then the tv, if not the remote won't do nothing. The player will shut's itself down after kodi's timer of inactivity has expired.
NPN
Pete Milne
Yaroslav Zhilin
Classic :-D
